1/2 NPT Internal Mix 360° by Exair
1/2 NPT internal mix 360-degree hollow circular pattern atomizing spray nozzles that can be used to coat the inside of large diameter pipe or duct
The 1/2 NPT internal mix 360-degree hollow circular pattern atomizing spray nozzles are ideal where a liquid application is needed in a broad area, such as dust suppression, humidification and cooling. They can also be used to coat the inside of large diameter pipe or duct.
Exair
Learn more about the product in the New Products for Engineers Database.
Original content can be found at gspplatform.cfemedia.com.
