Industrial and manufacturing employees require safety gear on the plant floor. Learn four ways to encourage PPE use.
Learning objectives
- Identify the key psychological and practical reasons why workers resist using PPE.
- Recognize how workplace culture and leadership influence PPE compliance.
- Apply evidence-based strategies to improve consistent PPE use.
- Demonstrate the role of empathy and communication in strengthening PPE compliance.
PPE insights
- Even with clear rules, some workers avoid PPE because of discomfort, inconvenience or a belief that it’s unnecessary.
- This article explores the psychological barriers behind PPE noncompliance and how leaders can overcome them through communication, design improvements and positive reinforcement.
- By addressing the human side of safety, organizations can encourage consistent use and reduce risk.
On a jobsite in Southern California, fewer than two-thirds of the workers were found to have kept their personal protective equipment (PPE) on throughout their full shift. Most of them admitted to taking off their gloves and respirators, which is a common occurrence for those who work in confined spaces. Once heat starts to build up in these spaces, the crews are going to look for ways to keep themselves comfortable. That’s a natural response, but it isn’t always a safe one.
The Occupational Health and Safety Administration has dedicated decades to implementing PPE standards. Below is a summary of these standards.
Billions of dollars have been invested on safety. But still, noncompliance remains a clear problem. In the construction industry alone, workers are more than five times as likely to die on the job as compared to other industries. And still, it is common to see some workers with their hard hats hanging on their belts instead of wearing them.
If PPE is designed to offer protection, then why do some workers still resist wearing it? Studies and simple interviews point to the same reasons: human factors. These factors, such as discomfort, cultural norms and even pride can all affect the way workers use their gear.
Reasons PPE use is ignored
It’s too hot to breathe in this thing.
This or a version of it, is a common phrase in a lot of industries, mostly for tradesmen. On that jobsite in Southern California where it gets hot easily, taking the risk to take off a respirator sounds better than not being able to breathe at all. Many workers are doing this not because they purposely do not want to wear PPE. They do it because the PPE itself can be more punishing than the risks.
Across the construction, manufacturing and health care industries, a 2025 study found that only a minority of workers consider their PPE as comfortable enough for them to use on a full shift. They mostly complain about the heavy hard hats, thick gloves that hinder their dexterity and masks that hinder them from breathing properly. These are serious concerns. A worker who feels their hard hat is too heavy or uncomfortable may be at greater risk of falling or slipping. With restricted dexterity, some may exert more force and risk getting injured. And wearing a respirator that hinders them from breathing won’t feel like it’s protecting them.
Combining or wearing all necessary PPE for compliance can lead to heat buildup, pressure points and restricted movement. After just about 20 minutes of wearing a heavy helmet, goggles, respirator, tight harness and more, it can really become uncomfortable. And this feeling often leads to reduced concentration and taking shortcuts to finish the task.
In the end, when people can’t breathe, are sweating too much or are too tired to continue working, comfort will win against compliance.
I know I have to, but …
Workers know the risks. People who work in industrial environments know the dangers that come with the work. They know that skipping a hard hat may risk their lives. But the same workers would still skip the hard hat or the gloves when it gets uncomfortable or slows down production. This only means one thing: it is the worker’s attitude that affects their behavior in using or not using PPE and not their awareness of the risks.
Studies also agree. Surveys identified various reasons for PPE noncompliance, such as poor supervision, peer pressure, overconfidence and weak safety culture. Not ignorance of the risks or hazards. In fact, some workers are overconfident that they can avoid the dangers because they already know them. So, not using PPE does not mean the workers do not understand the risk; they do, but there’s always another reason not to do so.
Real men don’t need helmets.
Most high-risk industries are dominated by males. And there are social pressures that may damage safety campaigns just to prove being a “real man.” In some crews, wearing full PPE is still perceived as a sign of being weak or lacking skills.
Aside from this, compliance also depends on social norms. These include negative attitudes, peer influence and a lack of supervision. If workers perceive wearing PPE as negative, they affect each other’s perspectives in the long run. And without proper supervision from the management, it would be a challenge to encourage compliance. The truth is, if management takes PPE seriously and rewards workers who use it, then the culture will shift for the better.
I never had an accident anyway.
Feeling safe at work sounds nice at first. But it is true that the longer people work without experiencing an accident, the safer they feel, even without PPE. This is called “risk normalization.” And this usually happens among experienced workers. They may interpret years of not having an accident as proof that it is all right to skip certain precautions or safety gear.
Again, leaders or management can affect this mindset. If supervisors ignore small violations because a worker is “skilled” or has been in the industry for a long time, then other workers will view that as permission to do the same. Conversely, if leaders are consistent with enforcement and are seen to be following compliance, then the norm will dramatically change.
How to encourage PPE use
Workers are aware of the risks associated with not wearing PPE. They also know the rules. So what should leaders do to encourage PPE use? Target the four human factors: redesign for comfort, show empathy, be visible and consistent and educate by engagement.
1. Redesign for real comfort
Start the change with the gear itself. Invest in lightweight, breathable materials with better sizing. There are also advanced PPE that can predict when discomfort reaches a point where the user is most likely to remove the equipment. Personalizing PPE for each worker’s size can go a long way as well. The more comfortable workers feel wearing their gear, the more they are likely to wear it.
2. Make safety a social value
Publicly recognize and thank workers for using their PPE. Make it a rewarding experience. Give out incentives. Be loud about what kind of attitude and culture you would like to see in the workplace. Emphasize the rewards more than the punishment.
Doing peer mentorship can also improve safety culture. Pair model veterans with new hires so they can adopt good safety habits. This will also help reinforce the message that PPE compliance is a “professional pride” and not a sign of weakness.
3. Lead visibly and consistently
Workers will always look up to their superiors. Be consistent with enforcing PPE use and make sure that the leaders are the first ones who use them all the time. When managers wear the same gear, it gives them credibility. But when the leaders themselves ignore small violations, then all other efforts for safety culture will go to waste.
4. Educate by engagement
Forget lectures and slide presentations. Interactive demonstrations and hands-on simulations are what would really make a change. Even brief training sessions that are focused on engagement can boost PPE use. Other ways to make training interesting include using gamified safety challenges, storytelling about real incidents and even peer audits with the intention to encourage and not simply correct.
At the end of the day, crews do not need another poster to look at and ignore; they need participation and involvement.
Acknowledge the human side of safety
Compliance is not just about the policy or the rules and standards. It involves the human side of safety and how the workers experience safety.
When workers slip off their gloves or remove their heavy hard hats, they are not defying the rules. They are just coping with poor PPE design. Understanding this truth gives management a clearer picture of what really matters. It is important to listen to the discomfort complaints, find and design new gears and engage workers in selecting the PPE that is meant to protect and save them.
The lesson is clear: discomfort is the No. 1 barrier. Visible leadership and positive incentives drive lasting change and the human side of safety, which includes comfort, trust and communication, remains the most powerful control measure.
Availability and provision of PPE alone are never enough. Address the discomfort, redesign for reality, rebuild trust and the next safety meeting might start with good news.
