Tower fill cleaning system
The TFC-100 TowerWash is designed to enable a user to clean and rinse up to 500 square feet of cooling tower fill in 15 minutes. The unit injects compressed air into a mixed stream of water and cleaning solutions, providing a thick, rapidly advancing foam that navigates through the fill. It is followed by a low-pressure, high-flow power rinse to wash away debris.
The TFC-100 TowerWash is designed to enable a user to clean and rinse up to 500 square feet of cooling tower fill in 15 minutes. The unit injects compressed air into a mixed stream of water and cleaning solutions, providing a thick, rapidly advancing foam that navigates through the fill. It is followed by a low-pressure, high-flow power rinse to wash away debris. The unit is equipped with a continuous-duty air compressor, a stainless-steel spray gun and heavy-duty, chemical-resistant components.
Goodway Technologies Corp. : www.goodway.com
Plant Engineering
Plant Engineering Staff
