Terminal block with screw clamp terminations and is rated at 26 to 10 AWG solid or stranded wire terminations at 30 Amps at 600 Volts.
Terminal block with screw clamp terminations and is rated at 26 to 10 AWG solid or stranded wire terminations at 30 Amps at 600 Volts. The functionality of two feed through terminal blocks is found on one 6.2 mm wide block, which frees up space on a standard 35 mm DIN rail for other components. Nickel plated copper alloy metal bodies and high tensile screws ensure optimum contact. The housing is made of flame resistant UL940V0 housing.
Automation Systems Interconnect (ASI), Inc.
