Swivel fittings for tight, confining spaces
NPT swivel fittings are designed for applications in tight spaces or requiring precision positioning for achieving desired results.
NPT swivel fittings are designed for applications in tight spaces or requiring precision positioning for achieving desired results. This 303 stainless steel swivel can be pointed exactly where work needs to be done. A 50 degree total angle of adjustment provides the movement necessary for nozzles to be in the best position for maximum effectiveness. The NPT swivels can be used with 316 stainless steel, zinc, aluminum, and alloy nozzles. These swivels can improve nozzle effectiveness when replacing existing, wasteful nozzles or open tubes and are ideal for blowoff, cooling, and drying applications.
Exair Corporation
www.exair.com
