Victaulic's stainless steel Advanced Groove Systems (AGS) fittings deliver fast, reliable piping system installation and facilitate proper coupling positioning for increase coupling-to-pipe engagement.
Victaulic’s stainless steel Advanced Groove Systems (AGS) fittings complete large-diameter grooved mechanical piping systems in stainless steel. The fittings offer assembly speed and performance. AGS stainless steel fittings are available in 90- and 45-deg elbows, tees, reducers, adapters and caps. The AGS groove facilitates proper coupling positioning and provides increased coupling-to-pipe engagement. AGS handles higher end loads and a higher pressure rating-up to 350 psi (2,410 kPa)-with a three-to-one safety factor. AGS stainless steel fittings are available in 14- to 24-in. (350 to 600 mm) sizes and are fabricated from Type 304/316 stainless steel.
Victaulic
