Stainless steel connectors
The expanded family of Corrosion Resistant Stainless Steel (CRSS) Connectors are designed for use in washdowns and high moisture environments
The expanded family of Corrosion Resistant Stainless Steel (CRSS) Connectors includes standard cord connectors, liquidtight conduit fittings, watertight conduit hubs, jacketed metal clad cable connectors and ventilation plugs. Custom stainless steel connectors in small or large quantities are also available. The CRSS Connectors are designed to provide durability against corrosion, harsh climatic conditions, harmful environmental influences and high humidity. These connectors are also recommended for use in washdowns or high moisture environments. Other features include seven conduit sizes and IP 68 rated fittings. The ventilation plugs come in three thread sizes and are rated IP 69K.
Remke
www.remke.com
Plant Engineering Staff
This is Plant Engineering!
