Stainless steel comfort panel
The TP1900 HMI INOX comfort panel is designed with a stainless steel front making it ideal for food and beverage, pharmaceutical, cosmetics, fine chemical applications, and other hygienic-intensive areas.
The TP1900 HMI INOX comfort panel is designed with a stainless steel front making it ideal for food and beverage, pharmaceutical, cosmetics, fine chemical applications, and other hygienic-intensive areas. The human-machine interface (HMI) is equipped with analog-resistive touch sensor which helps implement a high IP66K degree of protection for tightness and stability. The 19-in. panel is designed for easy cleaning and its 240 grit hairline finish with minimized gaps and grooves protects against microorganisms as well as splinter protection.
Siemens, Inc.
www.siemens.com
