Stackable right-angle Ethernet cables
The stackable right-angle Ethernet cable assemblies are designed to provide true Category 5e and Categofy 6 performance while maximizing panel density.
The stackable right-angle Ethernet cable assemblies are designed to provide true Category 5e and Categofy 6 performance while maximizing panel density. The specialized channel separator and load bar allows these stackable cables to achieve optimal performance and compliance with TIA/EIA-568 standards while maintaining a right-angle bend. The right-angle Ethernet cable assemblies are an ideal solution for tight-fit and dense connectivity applications commonly found in data center and enclosure applications.
L-com Global Connectivity
https://www.l-com.com/
