Sensors detect level of various liquids
The 07186 Series sensors provide level control on oil and water and mildly corrosive and high purity liquids. An infrared signal is transmitted to the tip. If the tip is wet, the signal refracts into the liquid.
The 07186 Series sensors provide level control on oil and water and mildly corrosive and high purity liquids. An infrared signal is transmitted to the tip. If the tip is wet, the signal refracts into the liquid. If the tip is dry, the signal reflects back to turn a circuit on or off.
Cole-Parmer Instrument Co.
www.coleparmer.com
Circle 386
