Sections: Grand Award | Gold Awards | Silver | Bronze |
6 competition, call Pat Mustari at 630-288-8775 or send her an email at [email protected] . Rules and entry forms are also available on our web site at plantengineering.com .
Grand Award
| Machine Vibration Basics |
The computer based training program on machine vibration basics covers the physical basis for vibration monitoring, vibration analysis through identification of discrete frequencies and clarifies why most anti-friction bearings fail prematurely and how failures can be eliminated. The training is interactive and downloadable, making it more cost effective than seminar attendance. New Standard Institute : www.newstandardinstitute.com |
Gold Awards
Compressed Air Cooper Compression Turbo Air 2020 Centrifugal Air Compressor |
Turbo Air 2020 centrifugal air compressor offers big performance in a compact package. It provides oil-free, reliable, efficient operation and ease of maintenance in a two-stage 250 to 400 hp air compressor. It brings lower maintenance costs with greater efficiency and all the advantages of oil-free compressed air. Units are easy to install. There is no air end replacement or disassembly, just simple filter changes. Cooper Compression : www.coopercompression.com |
Construction, Buildings, & Grounds Hilti TE 706-AVR Breaker |
TE 706-AVR breaker offers high chiseling performance and reduced fatigue. It features a state-of-the-art brushless SR-motor and an active vibration system. The lightweight breaker takes the effort out of chiseling when working on walls or floors. The unit requires no carbon brush replacement, so intervals between servicing are longer. Control electronics provide high motor power during voltage fluctuations. Hilti, Inc. : www.us.hilti.com |
Control Equipment Stealth Computer VU-HB High Brightness LCD Monitor |
StealthVU-HB series high-brightness LCD monitors are designed for high ambient light conditions. Monitors operate in direct or indirect sunlight. Features include stainless steel NEMA 4/IP66 enclosure for operation in harsh environments, plug & play capable, high resolution and a variety of touch screen options, including resistive, capacitive and surface acoustic wave. Stealth Computer Corp. : www.stealthcomputer.com |
Electric Motors, Drives, & Controls Schneider Electric Altivar 71 Variable Speed AC Drive |
Altivar 71 variable speed ac drive is designed for constant torque using 3-phase motors up to 700 hp. Dual microprocessors and motor control algorithms provide torque performance and speed regulation. Features include plain-text display with navigation wheel, quick-start menu with macros, common user interface, fieldbus/network connectivity, thermal and environmental protection and expandable I/O. Schneider Electric : www.us.telemecanique.com |
Electrical Power Fluke Corporation Fluke 434 Power Quality Analyzer |
Model 434 three-phase handheld power quality analyzer features automated recording, menu-driven interface and is rated to CAT III, 1,000 V/CAT IV, 600 V for all four channels. Measurements include true-RMS voltage and current, frequency, power, power consumption, unbalance and flicker. It also captures transients, interruptions, sags and swells. Users can view stored data while recording. Fluke Corp. : www.fluke.com |
Environment, Safety, & Health New Pig Corporation PIG Spillblocker Vacuum Dike |
The Pig Spillblocker Vacuum Dike attaches to a wet vacuum to create a floor-hugging barrier that contains liquids and speeds liquid recovers. When the vacuum is turned on, the Dike’s four intakes and integrated vacuum channels suck up the liquid more quickly than the traditional vacuum head. It is ideal for fast spill containment and removal. New Pig Corporation : www.newpig.com |
Fluid Handling Titan Piping CoPro Copper Pipe System |
CoPro push-to-connect copper pipe system teams high performance with unique functionality. The system offers simple, one-step installation with the flexibility to easily remove and reuse fittings. While installed, the fittings can be rotated without damaging the seal or pipe. The fittings work with copper, stainless steel, CPVC and PEX making them ideal for hot and coldwater service. Titan Piping Co. : www.titanpiping.com |
General & Maintenance Software Maintenance Connection, Inc. Maintenance Connection Mobile |
The Maintenance Connection Mobile allows maintenance technicians to use wireless devices to view work order assignments and take action on them. Technicians can also create new work orders in real time and look up information on the work history of a particular asset. A Bluetooth barcode scanner allows for identification of all assets. Maintenance Connection Inc. : www.maintenanceconnection.com |
Heating, Ventilating, & Air Conditioning MovinCool/Denso Sales California, Inc . Office Pro 36 Spot Cooler |
Office Pro 36 delivers 36,000 Btu/hr of cooling for up to 2,400 square feet Features include low temperature operation, which provides a cool environment for heat-sensitive equipment; an AFCI plug, a safety feature that protects against electrical arcing; and programmable controls for automatic operation. An optional Plug-N-Play pump can be installed to eliminate the need to manually drain the condensation tan. MovinCool/DENSO Sales California, Inc. : www.movincool.com |
Instruments Electrophysics HotShot Thermography Camera |
HotShot infrared thermography camera is designed specifically for industrial inspection of high-voltage electrical systems, production machinery and buildings. Features include an articulating thermal camera head, ergonomic design integrated data logger functionality, icon-based user interface, 3.5-inch LCD touch screen with on-screen control buttons, Compact Flash accessory port, USB port and active synchronization. Electrophysics : www.electrophysics.com |
Lighting Day-Brite Lighting APEX Luminaire |
APEX fluorescent low-bay luminaire is an energy saving replacement for 400W metal halide luminaires. It features 4, 80-W long twin-tube fluorescent lamps, designed with separate lamp and ballast components for maximum performance. Other features include instant on, multilevel switching for lighting control, dimming option, 90% lumen maintenance and 55 C ambient temperature rating. Day-Brite Lighting : www.daybritelighting.com |
Maintenance Products Rust-Oleum Rust-Reformer |
Rust-Reformer instantly converts rust into a non-rusting barrier in one easy step. It stops existing and future corrosion and is perfect for minimal surface preparation projects. The coating dries to a hard, flat black finish that can be top-coated with oil or latex paint. The convenient aerosol-propelled coating outperforms alkyd primers and other rust converters. Rust-Oleum Corp. : www.rustoleum.com |
Maintenance Tools & Equipment Spectronics Corporation Optimax Jr. Cordless Leak Detection Flashlight |
Spectroline Optimax Jr. is a leak detection flashlight that reveals refrigerant leaks in cramped areas inaccessible to larger lamps. It is 7 Spectronics Corp. : www.spectroline.com |
Material Handling New Pig Corporation PIG Under-Rack Containment Tray |
The Pig Under-Rack Containment Tray keeps floors dry by capturing drips and leaks underneath pallet racking. The tray is 2 New Pig Corporation : www.newpig.com |
Power Transmission Emerson Power Transmission Sealmaster PN Gold Mounted Ball Bearing |
Sealmaster PN Gold mounted bearings feature a high phosphorus, electroless nickel coated steel insert and a patented, multiple lip high performance seal that extends bearing life. These bearings were specifically engineered for industries with corrosive washdown environments. An exclusive pin and dimple system provides a direct lubrication path and Emerson Power Transmission : www.emerson-ept.com |
Training Products Ramsay Corporation Drafter (CAD Operator) Test |
Drafter, CAD Operator is a 30-question paper and pencil test which includes sections on Print Reading and CAD. The test takes 30 minutes to administer in its multiple-choice format. The results help employers choose the best candidate for the CAD operator position. Ramsay Corp. : www.ramsaycorp.com |
Silver
Compressed Air Atlas Copco Compressors Inc. GN Series Dual Output Air Compressor |
GN range of dual output air compressors generate nitrogen and compressed air simultaneously. 4 kW, 7 kW and 18 kW units are available with several levels of nitrogen output for each unit. Nitrogen flow starts at 0.6 cfm and goes up to 18 cfm with a purity of 95%. The dual output compressor system uses a screw compressor, tank mounted, an integrated refrigerant dryer and filters and a membrane that passes nitrogen. Atlas Copco Compressors Inc. : www.atlascopco.us |
Construction, Buildings, & Grounds Frommelt Products Corporation Survivor Dock Shelter |
Survivor dock shelter features an innovative, impactable side frame design specifically engineered to eliminate costly damage that often occurs when semi-trailers make contact with loading dock shelters. Virtually indestructible Neotec, high molecular weight polyethylene, side frames allow these shelters to be struck by trailers from any angle without suffering permanent damage. Frommelt Products Corp. : www.ritehite.com |
Control Equipment Burkert Contromatic Corp. Type 8041 Electromagnetic Flow Transmitter |
Type 8041 electromagnetic flow transmitter is designed to operate as a transmitter and/or on/off control. It is able to function at high temperatures and pressures, and is compatible with pipe diameters from Burkert : www.burkert-usa.com |
Electric Motors, Drives, & Controls GE Fanuc Automation PACSystems DSM324i Motion Controller |
PACSystems DSM324i motion controller features a fiber-optic interface, improved speed and torque range, smaller size, low inertia, tight integration with the flexible PAC control platform and incremental or absolute positioning feedback. Fiber optic interface increases the distance between servo nodes to up to 100 meters while improving electrical noise immunity and reducing wiring costs. GE Fanuc Automation : www.gefanuc.com |
Electrical Power General Electric Low Voltage Switchgear Remote Racking Device |
Low Voltage Switchgear Remote Racking Device allows users to rack circuit breakers in and out from up to 30 feet away, drastically reducing the potential for an arc flash injury. The electric motor is operated using 115 Vac via plug-in power cord. The gearbox is easily attached to the front of the circuit breaker with a sliding latch connection. Unit is available as retrofit or option with LV switchgear. General Electric : www.geelectrical.com |
Environment, Safety, & Health PowerFlare Corp. PowerFlare Safety Light |
The PowerFlare PF-200 safety light is compact at just 4 inches, but emits 360 degrees of bright LED light visible for up to 10 miles. It is waterproof and unbreakable. It features lithium batteries that allow a shelf-life of up to 10 years and can work in extreme temperatures. PowerFlare : www.shopbowhead.com |
Fluid Handling Nvent LLC PermaLynx Permanent Push-to-Connect System |
PermaLynx permanent push-to-connect piping system includes valves and fittings. Flame-free installation means no noxious fumes that can pollute the working environment. Installers can align joints fast and rotate them before pressurization. After pressure is introduced, the system stiffens and prevents rotation. No drying is needed on startups, minimizing down time. Nvent : www.nventsolutions.com |
General & Maintenance Software Peak Industrial Solutions, LLC Plant Engineering Tools Suite |
The Plant Engineering Tools Suite gives engineers the ability to solve problems quickly with a wide array of solution-based applications. The suite gives plant engineers the ability to create their own equations for future implementation. The 400 programs are compatible with desktop, Palm and Windows CE applications. PEAK Industrial Solutions LLC : www.cmmsmadeeasy.com |
Heating, Ventilating, & Air Conditioning Roberts-Gordon, LLC Vantage Modulating Infrared Heater |
Vantage Modulating heater is the first infrared fully modulating heater. It provides increased fuel efficiency by modulation, resulting in optimum combustion throughout the full range of burner inputs. The heater has comprehensive onboard diagnostics for fault and system status to provide information and ease of service. Burner modulation can be automatic or manual to suit the application. Roberts-Gordon LLC : www.rg-inc.com |
Instruments Timken Company, The StatusCheck Condition Monitoring System |
StatusCheck intrinsically safe condition monitoring system is designed to detect excessive levels of temperature and vibration in bearings, gears or machine elements that could lead to overheating and breakdown of critical equipment. The wireless product measures ambient temperature, has two-axis vibration detection, does not interfere with machine operation and comes with customizable software. The Timken Co. : www.timken.com |
Lighting Philips Lighting Company Long Life T12 Fluorescent Lamp |
Long Life 34-W T12 fluorescent lamp is a new version of the 34-W T12 fluorescent tube. Lamp offers 20% more life than previous 34WT12 lamps, which could translate into one additional year of lamp life, which reduces maintenance costs significantly. The lamp provides a retrofit solution that operates on existing ballasts and maintains reduced mercury content. Philips Lighting Co. : www.philips.com |
Maintenance Products Dissipater Mfg./ITW Delpro Dissipater Battery Vent Cap |
Dissipater battery vent cap solves many maintenance problems. A patented design dissipates heat and returns water to the battery during charging. Overflow protection holds expanded acid during recharging, eliminating over-watering. A built-in eye indicates the electrolyte level in every cell. A patented filtration system reduces harmful gases by filtering odors and creating a healthy environment. Dissipater Mfg./ITW Delpro : www.dissipater.com |
Maintenance Tools & Equipment Ludeca, Inc. Rotalign Ultra Laser Alignment System |
Rotalign Ultra features a backlit color screen and keyboard ideal for any working condition, day or night. Intuitive navigation guides the user to align a simple pump/motor or up to 14 machines. The unit offers USB and Bluetooth connectivity for interfacing with printers and PCs. A patented single beam technology has a 5-axis, 2-plane sensor and built-in position detector. Ludeca, Inc. : www.ludeca.com |
Material Handling Rite-Hite STR-4000 Dok-Lok Vehicle Restraint |
The STR-4000 Dok-Lok improves safety and productivity by stabilizing the dock trainer in both vertical and horizontal directions. The STR-4000’s rotating hook wraps up and over the trailer’s rear impact guard to minimize accidents due to unexpected trailer separation and tip-over. It is automatically positioned by the truck as it approaches the dock. Rite-Hite Corporation : www.ritehite.com |
Power Transmission Vestil Manufacturing Corporation Wire-D Caddy |
Wire-D is a wire and spool rack that holds spools of wire and has an optional hand truck for easy transport. The rack is of all steel construction and has 20 Vestil Mfg. Corp. : www.vestil.com |
Training Products Humantech Ergonomics Poster Series |
Nineteen new ergonomics posters launched to provide straightforward and accurate visual reminders of issues and solutions for improving workplace ergonomics. They reinforce an organization’s ergonomics activities and promote any company initiatives. The posters are offered in two series: the Awareness poster line or the Art poster line. Humantech Inc. : www.humantech.com |
Bronze
Compressed Air Gorbel Inc. Soft Touch Penumatic Control Handle |
Soft Touch Pneumatic Control Handles can be used with any air actuated end effector. These handles are a direct replacement for any standard pneumatic handles. They are engineered for easy use, reducing the potential for fatigue and repetitive stress injuries and require less than 1.5 pounds of depression force. The design uses spool valves instead of poppet valves. Gorbel, Inc. : www.gorbel.com |
Construction, Buildings, & Grounds Vestil Manufacturing Corporation Removable Ornamental Steel Bollard |
Model BOL-OR-40 is a functional, ornamental steel barrier to vehicle access and parking. It locks into a galvanized steel socket that is cemented into the ground. When the bollard is removed, a socket cover protects the hole, leaving no protrusion above the surface. The unit has a usable height of 40 inches, a diameter of 5 Vestil Mfg. Corp. : www.vestil.com |
Control Equipment Schneider Electric Twido Nano Controller with Bluetooth Wireless Gateway |
Twido nano PLC with Bluetooth wireless gateway can be programmed through either Bluetooth wireless or Ethernet. This allows wireless control up to 30 feet from PLC and the capability to monitor diagnostics and troubleshoot using a PDA, simplifying maintenance and troubleshooting for plant personnel. Features include four high-density analog I/O expansion modules and enhanced processor with embedded real-time clock. Schneider Electric : www.us.telemecanique.com |
Electric Motors, Drives, & Controls TB Woods Incorporated E-trAC X4 AC Drive |
E-trAC X4 variable speed ac drive features an IP66-rated enclosure that exceeds NEMA 1, 12 and 4x standards. The drive is available in 1—10 hp models, and voltages that include 115, 230, 460 and 575 Vac. Features include wireless IR programming via PDA; startup macros; extra relays, inputs and outputs; fault tolerance; 120% overload for one minute; and 150% momentary overload. TB Wood’s Inc. : www.tbwoods.com |
Electrical Power Caterpillar Gen Set with ACERT Technology |
Gen Set with ACERT Technology is designed for standby and load management applications. The generator set meets EPA Tier 2 requirements, delivers improved fuel efficiency and higher power density in a smaller footprint. Available in 60 Hz and 50-Hz models, the C32 clean diesel generator set is powered by a 32-liter, 12-cylinder, “V” configured engine with electronic fuel injection. Caterpillar : www.cat.com |
Environment, Safety, & Health Scientific Technologies, Inc. OptoShield OS3100 Laser Light Safety Scanner |
The OS 3100 OptoShield is an advanced safety laser scanner. It uses laser light to sense an intrusion into a guarded area. It can be configured for multiple irregularly-shaped hazardous areas for use in guarding work cells, transfer lines, robot stations or automated guided vehicles. Scientific Technologies Inc. : www.sti.com |
Fluid Handling MedHesives, Inc. Field Service Tech Rapid Repair Kit |
Field Service Tech Rapid Repair Kit provides facilities maintenance and field service technicians with a valuable tool for time critical pipe and tank repairs. Kits are based on an innovative cure-on-command resin technology developed from Department of Defense funded research associated with underwater resin systems. The kit contains the elements for completing repairs under harsh conditions of temperature and moisture. MedHesives, Inc. : www.northsearesins.com |
General & Maintenance Software GE Fanuc Automation Proficy Change Management Ver. 5.0 |
The Proficy Change Management Version 5.0 is an upgrade on the plant-wide automation management and control software that allows users to increase productivity and flexibility while also meeting regulatory requirements. Capabilities include security, version control, audit trails, central storage and automated backup and recovery. GE Fanuc Automation : www.gefanuc.com |
Heating, Ventilating, & Air Conditioning Goodway Technologies Corp. CoilPro Cleaner |
CC-120 CoilPro is the solution for coil cleaning operations. Many coil cleaner chemicals can damage coils or create noxious fumes. The unit operates on ac power or an integrated, rechargeable battery. Features include durable stainless steel wands, flexible extensions to clean hard-to-reach places, four nozzles to match the application, an integral water tank to eliminate hoses and an integral soap container. Goodway Technologies Corp., HVAC Maintenance Group : www.goodway.com |
Instruments IDEAL Industries, Inc. SureTest Circuit Tracer |
SureTest circuit tracer enables electricians to locate fuses and circuit breakers; pinpoint breaks in wires and shorts to ground; trace wiring concealed behind walls, floors and ceilings, as well as cables buried up to 15 feet underground. Features include variable pitch audible indication; peak detecting bar graph; four-mode operation; and capability to test both energized and de-energized circuits. Ideal Industries, Inc. : www.testersandmeters.com |
Lighting Venture Lighting International MP Halide Lamp |
MP 350W Natural White quartz metal halide lamp is designed for use with the high frequency electronic ballast. It features 90+ CRI and a color temperature of 5,000 K. Designed for applications where continuous deep dimming is desired, lamps can be dimmed down to 35% of lamp power when operated with approved electronic ballasts. Lamp features 90% lumen maintenance. Venture Lighting International : www.venturelighting.com |
Maintenance Products Sherwin-Williams Company, The Hydrogloss Waterbased Urethane |
Hydrogloss single component, water-based urethane delivers VOC compliance and performance comparable to a two-component water-based urethane but with the ease of application available only in a one-component system. Formulated to provide a high gloss finish with outstanding interior and exterior color and gloss retention, it also resists yellowing. It can be brushed, rolled or sprayed with no additives. The Sherwin-Williams Co. : www.sherwin-williams.com/im |
Maintenance Tools & Equipment Stanley Proto Blackhawk Rotator Ratchet |
Blackhawk Rotator Ratchet looks and works like a standard ratchet and requires only a 6-degree arc swing. The tool is unique because it offers an alternative way to work. Twisting the handle causes a set of internal gears to engage to turn the socket. The handle will rotate 360 degrees in either direction and turn the socket in the same direction no matter which way it is twisted. This is ideal for tight places. Stanley-Proto : www.stanleyproto.com |
Material Handling Eriez Magnetics PolyMag Plastic Separator |
The PolyMag process for magnetic sorting infuses the plastic resin with high-concentration pellets during the manufacturing process. After granulation, magnetic separators are used to sort various types and/or colors of plastics. The quantity of the magnetic additive does not affect the physical properties of the plastic. Eriez Magnetics : www.eriez.com |
Power Transmission Garlock-Klozure Mill-right Family of Elastomer Materials |
MILL-RIGHT contact oil seals offer breakthrough wear, abrasion and chemical resistance over and above anything available on the market. In comparison with existing seals, these offer an improvement in wear life up to 90% which can easily double, triple or quadruple their useful life. More useful seal life means costly bearings last longer; machines run longer and need less maintenance. Klozure Dynamic Seals, Oil Seals Div. : www.klozure.com |
