The GAUSB-CRNM-LED-PC-M industrial grade LED beacon light is a magnetically mounted lighting solution for general work areas where permanent solutions are not feasible.
The GAUSB-CRNM-LED-PC-M industrial grade LED beacon light is a magnetically mounted lighting solution for general work areas where permanent solutions are not feasible. The seven-watt LED lamp is protected by a polycarbonate lens, adding to the corrosion resistant features offered by the fixture. Light output colors offered by this fixture includes red, amber, blue, green, and white. The GAUSB-CRNM-LED-PC-M is equipped with a 100-pound grip magnetic base for mounting. This is appropriate in locations where the LED beacon is offered in a high voltage configuration, as well as a low voltage configuration and is terminated in a one-foot pigtail with flying leads for connection to the appropriate power source.
Larson Electronics
www.larsonelectronics.com
