Temposonics M-series sensors new connectors are designed to flush mount on the side of cylinders in mobile hydraulic applications. The design, based on an industry standard M12 interface, allows a small contact carrier insert to be pre-assembled. The insert fits through the cylinder and can be joined with the outer metal housing.
Temposonics M-series sensors new connectors are designed to flush mount on the side of cylinders in mobile hydraulic applications. The design, based on an industry standard M12 interface, allows a small contact carrier insert to be pre-assembled. The insert fits through the cylinder and can be joined with the outer metal housing. The connector has no pins to crimp on ends of wires, no loose connector pins and no wires to solder.
MTS Sensors Corp., Sensors div.
