The SRH301 and SRH302 are shaft-operated, rotary position sensors that offer safety for original equipment manufacturers (OEMs) designing vehicles and control systems.
The SRH301 and SRH302 are shaft-operated, rotary position sensors that offer safety for original equipment manufacturers (OEMs) designing vehicles and control systems. With a low-profile sensor body depth of 17.3 mm, and using the 28 mm diameter flanged housing with crush-proof mounting zones, these sealed IP69K-rated sensors are ideal against water, dust, shock, vibration, and temperature. The SRH301 is a 3-wire, single output variant with a supply current rating of less than 17.5 mA.​ The SRH302 is a 6-wire, dual-redundant output variant with a supply current rating of less than 35 mA. The dual-die sensor has two completely independent power connections and output channels for full electrical redundancy.
Curtiss-Wright
