Finalist in Electric Motors and Drives in Plant Engineering’s 2011 Product of the Year competition
The 5813 Frame Vertical Titan II is manufactured using a cast iron frame, which allows for the production of the winding and frame assembly to be done in parallel rather than in series. The 5813 Frame Vertical Titan II motor is custom built, based on customer specifications and requirements. It includes WPI and WPII (weather protected) enclosures, and ranges from 250 hp to 1750 hp depending on the required speed. The new motor is available as either hollow shaft or solid shaft in both low- and medium-voltage options. The Titan II features oil-lubricated bearings with several capacity designs available.
Nidec Motor Corp.
www.nidec-motor.com
View all finalists in the Electric Motors, Drives, + Controls category
