The NS-Series National Sanitation Foundation (NSF) certified potable water solenoid valves can be mounted in any position and a spring-loaded plunger assures positive shutoff.
The NS-Series National Sanitation Foundation (NSF) certified potable water solenoid valves can be used in food and beverage grade potable water applications. Stainless steel or thermoplastic bodies and synthetic seating and sealing materials makes NS series valves suitable for use with a variety of liquids, oils, and gases. Valve operation is normally closed and open when electrically energized. The valves can be mounted in any position and a spring-loaded plunger assures positive shutoff. NS201 and NS211 series are piloted diaphragm valves; NS201 series valves also can operate under zero pressure differential.
AutomationDirect
www.automationdirect.com
