The ST150 turbine air starter with 47 horsepower aluminum motor is designed for fast starts on mid-size, heavy-duty diesel and gas engines.
The ST150 turbine air starter with 47 horsepower aluminum motor is designed for fast starts on mid-size, heavy-duty diesel and gas engines. The ST150 Mid-Range Turbine Air Starter features a solid billet aluminum turbine motor with robust fins and nozzles to withstand harsh environments and debris in the airstream. The turbine technology housed in the ST150 does not require lubrication and powers 13 to 95 liter-size engines for reliable starts. The patented slip-fit motor design has half the parts compared to units from other manufacturers. ST150 rotors can be quickly and easily removed for serviceability and operators can change from low to high pressure in a matter of minutes.
Ingersoll Rand
