MicroPress MPZ 500-30 rack and pinion press is a hand-operated press which Image courtesy of Mäder Pressenparticularly suitable for precise fitting work in light engineering.
The MicroPress MPZ 500-30 rack and pinion press is a hand-operated press which particularly suitable for precise fitting work in light engineering, where the force needed is low but where the operator has to work both sensitively and precisely.
Capable of a force of 500 N with a manual tension force of 80 N, the working stroke is steplessly adjustable up to a maximum of 25 mm. The adjustable press head permits a daylight of up to 150 mm. At 1.5 kg, the press is very light and so can be operated without any problem at workstations in different locations.
Mäder Pressen
https://www.maederpressen.de/English:index:.asp
