Loading dock security
The New Guardian 3-in-1 Dor-Seal System improves security at the loading dock, plus improves dock seal mounting and improves sealing at the back of dock seal to building wall. The triple-duty design, keeps conditioned air and packages in and keeps people out. The system allows a truck to back into a loading dock and create a compression series dock seal.
The New Guardian 3-in-1 Dor-Seal System improves security at the loading dock, plus improves dock seal mounting and improves sealing at the back of dock seal to building wall. The triple-duty design, keeps conditioned air and packages in and keeps people out. The system allows a truck to back into a loading dock and create a compression series dock seal. A vinyl coated chain-link structure surrounds the foam padding to keep thieves from cutting through the pad to gain access to the trailer and your facility.
Heavy-duty wood or optional steel substructure lends stability and rigidity to the dock seal and provides a strong, secure connection to the mounting brackets. Soft foam conforms to the irregularities of building walls.
Chalfant Sewing Fabricators www.chalfantusa.com
