4QSS liquidtight fittings feature 316 stainless steel for wet, corrosive locations and is engineered for industries where sanitation is a critical concern such as food, beverage, and pharmaceutical.
The 4QSS liquidtight fittings feature 316 stainless steel for wet, corrosive locations and is engineered for industries where sanitation is a critical concern such as food, beverage, and pharmaceutical. The UL Listed fittings securely connect flexible metallic electrical conduit while completely sealing off liquids, vapors and solids. A nickel-plated ferrule provides maximum surface contact with longer, more pronounced threads to ensure pull-out protection and prevention of tight bend conduits to minimize replacements and service calls. 4QSS fittings are available in trade sizes ranging from 3/8- to 2-in., with body designs of straight, 45° and 90°. In addition to sanitary environments, the 4QSS fittings are well-suited for machine tool building, HVAC, robotics assembly, and areas rated hazardous by the NEC such as petrochemical processing.
Emerson
