Linear position sensors
LVDT SE 750 linear position sensors automate the testing process and reduce material testing laboratory lead time.
LVDT SE 750 linear position sensors eliminate the chance of human error and automate the testing process so measurements could be taken at different intervals to extend productivity. The SE 750 series of 3/4 in. sensors also provide high resolution, repeatability, and low hysteresis. With built-in electronics, the DC-operated LVDT sensors provide a pre-calibrated voltage output that interfaces with data loggers to automatically process results without waiting for data to be manually input into a computer. As a result of using LVDT sensors, the material testing laboratory lead time is reduced. This increases productivity by conducting thermal expansion testing on an as-needed basis without waiting for available operators.
Macro Sensors
www.macrosensors.com
