High-voltage PCB connectors
The GMSTB(A) 2.5 HC(V) is a high-voltage header and plug with screw connection for wire-to-board applications.
The GMSTB(A) 2.5 HC(V) is a high-voltage header and plug with screw connection for wire-to-board applications. It features a 7.62-mm pitch and voltage ratings of 1,000 V IEC, 600 V UL. The MKDS 5 HV is a high-voltage, fixed printed circuit mount terminal block for power applications. The design enables discrete wiring termination with a rising cage screw clamp on small 6.35-mm spacing. Front or back pinning options are available and an enlarged screw entry funnel eases wiring. Both feature touch-safe designs and are suitable for applications such as power electronics, frequency converters, power supply units, electric vehicles and motor connections. Phoenix Contact, Inc. www.phoenixcon.com
Plant Engineering
Plant Engineering Staff
