The 400-Watt high-bay light is a temporary lighting fixture designed for efficiency and use in commercial, industrial and warehouse work areas. The halide lamp meets OSHA 1926.56 requirements for minimum illumination of work bays. It outputs 36,000 initial lumens at 4,200 Kelvin color rendering. Additional features include a Type-O lamp and mogul socket, a spring-loaded clamp hook and a heavy-g...
The 400-Watt high-bay light is a temporary lighting fixture designed for efficiency and use in commercial, industrial and warehouse work areas. The halide lamp meets OSHA 1926.56 requirements for minimum illumination of work bays. It outputs 36,000 initial lumens at 4,200 Kelvin color rendering. Additional features include a Type-O lamp and mogul socket, a spring-loaded clamp hook and a heavy-gauge welded and plated wire-formed guard. It complies with NEC-2005 410.73(F) (5) and ANSI C78.387 standards.
Woodhead Industries , a div. of Molex : www.woodhead.com
