Grease gun with integrated grease meter
The TLGB 20 grease gun is a portable tool to maximize efficiency and accuracy of manual lubrication for bearings, machines, and off-road equipment across industries.
The TLGB 20 grease gun is a portable tool to maximize efficiency and accuracy of manual lubrication for bearings, machines, and off-road equipment across industries. An integrated grease meter adds value by dispensing the proper amount of lubricant for an application to prevent over- or under-greasing. The grease gun’s rechargeable 20-volt lithium battery delivers extended service life to enable timely manual lubrication of equipment anywhere and anytime in a manufacturing plant or in the field. This grease gun can dispense up to 15 grease cartridges per battery charge and delivers two flow rates adjustable for a specific application. Pressures up to 700 bar (10,000 psi) can be achieved.
SKF
www.skfusa.com
