Front harness
The Miller AirCore Front D-ring Harness meets OSHA and CSA requirements and is rated to 400 lbs. capacity
The Miller AirCore Front D-ring Harness meets OSHA 1926.502, ANSI A10.32, ANSI Z359.1 and CSA Z259.1-12 requirements and is rated to 400 lbs. (141.8 kg) capacity. In addition the AirCore Front D-ring Harness is available with either steel or aluminum hardware. Other features include breathable, open-core padding technology provides optimal airflow while reducing heat and moisture entrapment, keeping a worker drier and cooler. It also features cam buckles on the shoulder straps that make vertical webbing adjustment easy.
Miller Fall Protection
www.millerfallprotection.com
