Fittings and flow control valves for pneumatic cylinders
Nitra pneumatic G-thread fittings and flow control valves provide accurate airflow regulation for precise speed control of pneumatic cylinders.
The Nitra pneumatic G-thread push-to-connect fittings and flow control valves are made with thermoplastic (PBT) or nickel-plated brass bodies and stainless steel tube gripping claws and have a pre-applied O-ring to seal. Available in 4 to 10mm sizes, the bodies of elbow fittings can be rotated after installation to allow for variations in piping directions. These fittings are designed with a working pressure of -29.5" Hg to 150 psi and a working temperature of 32 to 140 F. The flow control valves provide accurate airflow regulation for precise speed control of pneumatic cylinders.
AutomationDirect
www.automationdirect.com
AutomationDirect
