The emPC-CXR embedded controller is ideal for extreme demands of temperature, moisture, size, shock, and vibration.
The emPC-CXR embedded controller is ideal for extreme demands of temperature, moisture, size, shock, and vibration. The emPC-CXR is designed for an ambient operating temperature range from -40 C to 70 C, and its compact housing measures 10.6" x 7.9" x 3.2". For shock resistance, the emPC-CXR complies with IEC 60068-2-27, with vibration compliance to IEC 60068-2-64. The systems also meets DIN EN 50155 for electronic equipment used in railway rolling stock applications. The emPC-CXR includes a number of moisture-proof interfaces, including two USB2.0 ports, a VGA port, a 9-34 V power supply input, and two M12 5-pin connectors for CAN or serial ports.
Saelig
