Electronic pressure switch
The PSW3000 is a high accuracy electronic pressure switch with 4 switching outputs plus a 0 to 10VDC or 4 to 20mADC analog output. Unit has an easy to read 4-digit display that shows reading plus set-point. A user scalable bar graph is also standard. The switch is housed in an IP65 rated aluminum casting designed for use in most industrial environments. Pressure ranges are 0 to 150 psi to 0 to 9000 psi. Perfect for chemical and automotive industries.
Omega
www.omega.com
