Desicorr is a desiccant pouch that comes in a windowed or windowless form and can be used for electrical applications such as semiconductors and electronics components.
Desicorr is a specially designed desiccant pouch that comes in a windowed or windowless form. The windowed version contains indicator spheres that change color from yellow to green to show when the desiccant is fully spent. The desiccant can be reused if heated to release the moisture previously captured. Desicorr Pouches NW (no window), replace the windowed portion of the package with a breathable membrane, allowing the desiccant to absorb moisture more quickly through both sides of the pouch. Desicorr Pouches NW are designed to protect goods within a sealed moisture barrier package. They are easy to insert manually or automatically-no degreasing or cleaning required. Successful usages include semiconductors, electronics components, circuit boards, optical devices, and communication devices.
Cortec Corp
