Marathon mounted bearing units integrate a stainless steel, dual-sealing system to protect against contaminants and resist corrosion.
Marathon mounted bearing units integrate a stainless steel, dual-sealing system to protect against contaminants and resist corrosion. The sealing arrangement consists of a double-lip insert seal, an AISI 304 stainless steel finger and a rubber-backed steel gasket. The units are available in sizes ranging from standard housing styles that include pillow block, two and four-bolt flange or tapped base, to a three-bolt bracket flange.
SKF USA Inc.
www.skfusa.com/mrc
