Work area blasting gun
BLG-LEDBLT-HGL-X24I is light equipped with a polycarbonate handle, a quick-change lens system, and a step down transformer for low voltage operation.
Larson Electronics’ BLG-LEDBLT-HGL-X24I, 18-watt work area blasting gun, is light equipped with a polycarbonate handle, a quick-change lens system, and a step down transformer for low voltage operation. It produces 1,530 lm of intense illumination that is designed for extreme durability in media blasting applications. The protective lens cover incorporates a simple drop in, drop out system behind a twist-on lens frame. The lens is offered in polycarbonate or hardened glass material. The LED light’s mounting system is designed to attach to the handle of a blasting gun. This LED blasting gun light operates on standard 120/277 V AC.
Larson Electronics
www.larsonelectronics.com
