The benefits of using high-efficiency motors
The use of high-efficiency, electric motors can lead to significant drops in energy use, as well as significant savings in cost. There are other factors, such as the difference in material quality and higher upfront costs, that need to be considered as well.
Lower maintenance cost
Another factor to consider is the higher standards of energy-efficient motors, including the materials and the manufacturing techniques. As a result, an energy-efficient unit has a longer life than a standard unit. Because of those higher manufacturing standards, you experience less vibration and lower heat.
In the end, an energy-efficient unit deserves careful consideration. Consider all factors before making a decision. Eventually, higher-efficiency motors pay for themselves in energy savings and lower maintenance costs.
David Manney is marketing administrator at L&S Electric. This article originally appeared on Watts New, L&S Electric’s blog. L&S Electric is a CFE Media content partner.
Original content can be found at lselectric.com.
