Precision RTD temperature data logger
The OM-CP-RTDTEMP2000 is a precision RTD temperature recorder with backlit LCD display. The unit is powered by a 9-V battery with a typical life of one year at a one-minute reading rate with the display off. An optional ac adapter is available for continuous use with the display and backlight on. This wall mountable unit has an eight-button keypad with lock feature and the large, backlit LCD di...
The OM-CP-RTDTEMP2000 is a precision RTD temperature recorder with backlit LCD display. The unit is powered by a 9-V battery with a typical life of one year at a one-minute reading rate with the display off. An optional ac adapter is available for continuous use with the display and backlight on. This wall mountable unit has an eight-button keypad with lock feature and the large, backlit LCD display provides convenient access to current data and recorder set up. NIST-traceable calibration is available for users needing to meet regulatory requirements.
Omega Engineering Inc. www.omega.com
Plant Engineering
Plant Engineering Staff
