Mobile power meter with silicon sensor
The PRONTO-Si, a mobile power meter with silicon sensor, is ideal for use in power measurement applications or testing of structural and equipment laser protective measures.
The PRONTO-Si, a mobile power meter with silicon sensor, is ideal for use in power measurement applications or testing of structural and equipment laser protective measures. When this compact device is folded up, both the sensor and the color touchscreen display are optimally protected. In the area of the silicon sensor, this device is just 6 mm thick and allows for power measurement even in very tight spaces. It quickly and precisely measures power levels significantly less than 1 nW and can be expanded into the three-digit mW range due to an integrated upstream OD1 attenuator.
LASER COMPONENTS
www.lasercomponents.com
