The e-Cart 2 is a mobile, temporary power distribution center. It has an industrial, powder-coated steel frame and is equipped with either a three-phase or a single-phase NEMA 3R 480-V or 600-V, 60-Hz ventilated transformer. Also standard are a NEMA 3R load center with GFCI breakers installed, and a NEMA 3R fused primary disconnect, both sized per transformer.
The e-Cart 2 is a mobile, temporary power distribution center. It has an industrial, powder-coated steel frame and is equipped with either a three-phase or a single-phase NEMA 3R 480-V or 600-V, 60-Hz ventilated transformer. Also standard are a NEMA 3R load center with GFCI breakers installed, and a NEMA 3R fused primary disconnect, both sized per transformer. An extra NEMA 3R fused disconnect is optional. Other features include 10-inch pneumatic tires, four cable hooks and four tie-down lift eyes.
Ericson Manufacturing Co. : www.ericson.com
