Mobile app program
The Altivar 212 mobile app contains menu-driven parameter sets that walk users through the drive configuration process
The Altivar 212 mobile programming application and drive to iPad converter cable allows users to perform all Altivar 212 and S-Flex drives programming through iPads. The application contains simple menu-driven parameter sets that walk users through the drive configuration process. Digitizing the start-up and programming of a drive streamlines the process, allowing customers to store pertinent drive information in a single location, and facilitates a standard drive configuration throughout a facility. The app enables an iPad to function as a drive keypad using pre-loaded common default parameters for HVAC fan and pump applications, significantly streamlining the configuration process.
Schneider Electric
www.schneider-electric.com
