Continue to Site
Hydrogen sulfide scrubbers
These refillable hydrogen sulfide scrubbers remove hydrogen sulfide from natural gas streams, facilitating the measurement of oxygen and other gases.
By Advance Instrument Inc. April 27, 2015
These refillable hydrogen sulfide (H2S) scrubbers and sample conditioning systems remove H2S from natural gas streams at the wellheads, booster stations, and/or pipelines to facilitate the measurement of oxygen and other gases. Specific only to H2S, other components in the gas stream are not affected. H2S scrubber tubes range from 1 to 2.5 in diameter and 6 to 24 in. in length. Inlet and outlet pipe fittings are 1/4 in stainless steel. Maximum allowable pressure is 30 psi/g and maximum temperature is 130 F. Using a 1.5 x 12 in H2S scrubber with 0.01% (100 PPM) H2S present, at 1/3 SCFH (150 sccm) the approximate life of the consumable media is 368 days.
www.aii1.com
