Hybrid laser analyzer
The Rosemount CT5100 is a hybrid gas analyzer that combines Tunable Diode Laser (TDL) and Quantum Cascade Laser (QCL) measurement technologies for process gas analysis and emissions monitoring.
The Rosemount CT5100 is a hybrid gas analyzer that combines Tunable Diode Laser (TDL) and Quantum Cascade Laser (QCL) measurement technologies for process gas analysis and emissions monitoring. It can detect down to sub ppm level for a range of components, while simplifying operation and significantly reducing costs.The CT5100 can measure up to 12 critical component gases and potential pollutants simultaneously within a single system-meeting local, state, national, and international regulatory requirements.
The CT5100’s laser chirp" technique expands gas analysis in both the near-and mid-infrared range, enhancing process insight, improving overall gas analysis sensitivity and selectivity, removing cross interference, and reducing response time. The laser chirp technique produces sharp, well-defined peaks from high resolution spectroscopy that enable specificity of identified components with minimum interference and without filtration, reference cells, or chemometric manipulations.
Emerson Process Management
www.EmersonProcess.com
