How to select PPE to protect against airborne hazards
If airborne hazards are a respiratory concern, learn about the PPE available.
- Gain resources from regulatory bodies regarding the use of respiratory protection products.
- Know situations in which respiratory protection should be used, and the different types of respiratory protection that are suitable for those specific situations.
PPE insights
- Personal protective equipment (PPE) is critical for worker safety.
- Air quality regulations are important considerations for the types of PPE required for worker protection.
It may sound counterintuitive that the least-effective control is the one many people think of first. It is, however, the one the user will ultimately be most familiar with, so it’s critical to know if –– and when –– different personal protective equipment (PPE) will provide adequate safeguards for airborne hazards.
Per Occupational Safety and Health Administration (OSHA) 1910.134(d)(1)(iii), the responsibility for this rests with the employer:
The employer shall identify and evaluate the respiratory hazard(s) in the workplace; this evaluation shall include a reasonable estimate of employee exposures to respiratory hazard(s) and an identification of the contaminant’s chemical state and physical form. Where the employer cannot identify or reasonably estimate the employee exposure, the employer shall consider the atmosphere to be immediately dangerous to life or health.
Manufacturing safety personnel should assess the nature and magnitude of respiratory hazard(s) that personnel may be exposed to. This includes hazards present during normal operations, as well as those that may be the result of accidental releases or emergency situations. It will also identify the physical state, such as gas, particulate or both and chemical form, including toxin, corrosive element, carcinogen and biohazard, of the contaminant(s).
Oftentimes, the contaminant is a substance that’s used by the worker. In those cases, OSHA publishes a Hazard Communication Standard, which mandates hazard identification on safety data sheets. This is a valuable tool and is largely considered to be the primary source of information for any hazards associated with the substance in question. If the contamination is a result or byproduct of an operation, air sampling of the actual environment or objective information from similar operations may be necessary.
Respirator selection for air contaminants
The next consideration will be the factors that might influence the selection of which specific kind of respirator is required. These factors include:
- Physical constraints of the job site. This typically won’t be an issue if a simple mask or cartridge filter-type respirators are to be used, but if the environment calls for an independent supply of breathing air, hose fed breathing masks may be needed in tight quarters. Consequently, the use of respirators with air hoses could be limited if there are obstructions in the area and could be downright dangerous around moving machinery. In those cases, a self-contained breathing apparatus will be the better option.
- Certain medical conditions. Many common respirators are classified as negative pressure devices. This means that the wearer must draw air in through a restriction (like filtration media or chemical cartridges), which means it takes more effort than just “normal” breathing. These aren’t suitable for everyone — for example, they present a very real risk of undue pressure to the heart for someone suffering from lung diseases such as asthma or emphysema. Positive pressure respirators provide a restriction-free flow of breathing air and need to be used in those cases.
- User comfort. It’s not good for anyone to burden workers with awkward or unwieldy PPE of any kind. That can lead to lost productivity, high turnover and possible legal action for the employer and myriad mental and physical stresses for the employee. Fortunately, technical and material improvements continue to make safety equipment lighter, easier to don, softer on the skin –– and many times even more effective than before.
- Required level of protection. Sanding drywall and cleaning up after an accident at a chemical plant present vastly different breathing hazards, and hence, need vastly different levels of protection. Agencies like National Institute for Occupational Safety and Health (NIOSH) and OSHA, as well as the American National Standards Institute, all have many standards and publications on this subject.
Know what PPE to select for airborne hazards
Once the appropriate level of protection is determined, users can select a suitable respirator from two basic categories: air-purifying respirators and atmosphere-supplying respirators.
Air-purifying respirators are self-contained devices that remove contaminants from the air to make it safe to breathe. Different kinds can remove particulates, vapors or both. They are all classified as negative pressure devices, so they may not be suitable for use by someone with medical conditions as noted above.
Particulate respirators capture airborne particles in small spaces between the fibers that make up their construction. These include simple masks that cover the mouth and nose and are typically considered disposable. They also come in a rigid frame with replaceable filter elements. As particulate accumulates in the fiber, these become more effective after some use but take care to replace them when any resistance or breathing difficulty is noted.
Figure 1: Here are three examples of air purifying respirators. Top: High-efficiency P100 cartridge-type respirator for organic vapors, chlorine, hydrogen chloride, sulfur dioxide or chlorine dioxide. This respirator can also be used for hydrogen sulfide but only in an emergency to escape from the contaminated area. Bottom: Two particulate mask-type respirators for general purpose use. Courtesy: Exair
Vapor respirators use chemical filters (usually in a cartridge or canister) which absorb the vapor. There are different specific types for different vapors; NIOSH has a color-coding system for them:
- Black: Organic vapors
- Bright green: Ammonia
- White: Acid gases
- Yellow: Organic vapors and acid gases
- Olive/brown: Organic vapors, ammonia, acid gases
- Magenta: High-efficiency filter, P100 filters
- Black, magenta: Organic vapors and high-efficiency filter, P100 filters
- Yellow, magenta: Organic vapors, acid gases and high-efficiency filter, P100 filters
- Olive/brown, magenta: Organic vapors, ammonia acid gases and high-efficiency filter, P100 filters
Combination respirators have both particulate and vapor filters. These are especially popular when working with pesticides, as well as other chemical or biological agents that create airborne particulate and vapor contaminants.
Specialty respirators as PPE
Atmosphere-supplying respirators provide clean breathing air from an outside source, usually an air tank or compressed air system. They’re used when a high concentration of contaminants could foul particulate elements or expend a vapor cartridge quickly. They may also be needed in areas where the oxygen level could drop below safe levels, such as confined spaces that cannot be adequately ventilated with fresh air. They’re also used for emergency situations to allow personnel to safely evacuate an area where the atmosphere is unexpectedly fouled with smoke or other pollutants.
All atmosphere-supplying respirators provide protection against particulate and vapor contaminants and come in three configurations:
- Air-supplied respirators consist of a mask (usually full face with straps to cinch it up for an airtight seal), with a short, low-pressure hose connected to a regulator, usually made to clip on the wearer’s clothing, belt, etc., which is fed with a hose rated for the supply pressure that has a quick connect for use with breathing air manifolds. These manifolds will normally be strategically located in facilities where contaminated atmospheres require their use. Advantages include their light weight and ability to provide clean breathing air for long periods of time. Disadvantages are limited mobility (the wearer can’t go any further than the supply hose length from a supply manifold) and failure due to hose damage.
- Self-contained breathing apparatuses have the same masks designed for an airtight seal but are fed with breathing air from a pressurized tank. The wearer has greater freedom of movement –– they’re not restricted to the supply hose length of an air-supplied respirator –– but they do have time limits.
- Open-circuit types provide breathing air that the wearer breathes right back out to the atmosphere. These are typically good for 30 to 60 minutes, because the larger the tank gets, the more cumbersome it is for the wearer to carry around.
- Closed-circuit types recirculate exhaled air through a chemical-activated “scrubber” that removes carbon dioxide and generates oxygen. These are also called “rebreathers,” and some are good for up to four hours.
- Combination atmosphere-supplying respirators combine features of the other two types. The primary supply comes from an external source (like the air-supplied ones), but they also include an air tank (like the self-contained ones). The tank is generally smaller on these, as its main purpose is to provide air while the user exits the area. They’re commonly used in confined spaces without adequate ventilation and when working for extended periods in atmospheres that could be immediately dangerous to life and health.
Proper selection and use of respiratory protection is critical to your health and safety. Additionally, it’s important to your company’s bottom line. In 2021, OSHA recorded 2,521 violations of respiratory protection standards. This was second only to fall protection violations that year. The associated fines are commonly compounded per person and per day.
Know and understand the hazards you and your employees will be exposed to. Familiarize yourself with the different respirator options. Conduct regular training so everyone knows how to protect themselves and others. Fit testing of respirators should be an integral part of that training.
Russ Bowman is an application engineer at EXAIR.
