Geared Bearing solutions comes with a zero backlash gear mounted and dialed in on a precision grade high capacity bearing and are preconfigured for fit, form and function, for easy integration into any precision rotary motion application.
Geared Bearing solutions comes with a zero backlash gear mounted and dialed in on a precision grade high capacity bearing. The Geared Bearings are available in a wide variety of sizes and gear ratios, and preconfigured for fit, form and function, for easy integration into any precision rotary motion application. The Product Selector tool is designed to make it easy to select the gear needed. Original equipment manufacturers (OEMs) also have easy access to STEP files and specifications. They also feature high indexing precision as low as ± 30 ArcSec with repeatability as low as ± 5.0 ArcSec. They have a high output load capacity supported by cross-roller bearing and can handle speeds up to 632 RPM.
Nexen Group, Inc.
www.nexengroup.com
