Double-diaphragm pumps with welded flanges
The Husky line of corrosion-resistant stainless steel air-operated double diaphragm (AODD) pumps has expanded to include stainless steel ANSI/DIN welded flanges.
The Husky line of corrosion-resistant stainless steel air-operated double diaphragm (AODD) pumps has expanded to include stainless steel ANSI/DIN welded flanges. The flanges are available in vertical and forward-facing orientations and feature a rotatable design that simplifies connection to process piping. The line of Husky AODD pumps range from 1/4-inch to 3-inch connections and produce flow rates up to 300 gallons per minute. They are configurable in a wide variety of pump body materials and wetted elastomers.
Graco
