Distributed controller
The Simatic ET 200pro I/O system is an IP65/67-rated distributed controller, with integrated Ethernet and Profibus communication, that does not require a control cabinet; it can be mounted directly on the machine. The modular CPU can be operated with an MPI interface; either a DP slave or DP master on Profibus DP; either an I/O controller or a Profinet CBA device on Profinet; and has 256 KB of ...
The Simatic ET 200pro I/O system is an IP65/67-rated distributed controller, with integrated Ethernet and Profibus communication, that does not require a control cabinet; it can be mounted directly on the machine. The modular CPU can be operated with an MPI interface; either a DP slave or DP master on Profibus DP; either an I/O controller or a Profinet CBA device on Profinet; and has 256 KB of work memory and a buffered hardware clock.
Siemens Energy & Automation, Automation & Motion div. : www.sea.siemens.com
Plant Engineering
Plant Engineering Staff
