Digitizers with fully synchronous multi-channel acquisition
The LXI-based DN.649x series is designed for applications where a large number of signals need to be acquired and analyzed with speed and precision such as sensors, detectors, rectifiers, antennas and other electronic devices.
The LXI-based DN.649x series is offered from 24 to 48 fully synchronized channels and are designed for applications where a large number of signals need to be acquired and analyzed with speed and precision such as sensors, detectors, rectifiers, antennas and other electronic devices. Each channel of a DN6.49x series digitizer is equipped with a high precision 16 bit analog-to-digital converter (ADC) and a versatile front-end amplifier that features six input ranges from ±200 mV up to ±10 V, and programmable offset. The units feature a rugged chassis with integrated cooling, including a replaceable dust filter, and low noise power supplies. Front-panel BNC connectors are used for the channel inputs, external clock and external triggering, while LED lights provide a visual indication for the power, trigger and LAN status.
Spectrum Instrumentation
www.spectrum-instrumentation.com
