The LinearX 3 compression hip kit is an all-in-one solution that contains the essential tools needed to strip, cut, and terminate coaxial cables.
The LinearX 3 Compression Hip Kit is an all-in-one solution to connecting F-Type, BNC, and RCA compression connectors on coaxial cable. The kit contains the essential tools needed to strip, cut, and terminate coaxial cables. It is housed in a durable hip kit that can be worn comfortably on a belt. This value kit is designed for installers of home theater, CATV, satellite, and video surveillance systems. The kit has the LinearX 3 adjustable compression tool, the PrepPRO stripper for RG-59/6/6 Quad/Plenum coaxial cable, and the Data-T Cutter. The LinearX 3 compression tool is manufactured using all metal components. The handle has a double-dipped textured cushion grip for comfort and all-day use, plus a shorter spread distance in the open position for a comfortable compression cycle for all users.
Ideal Industries
