Compact stackers
The Power Stak line of fully powered stackers includes models with lift heights of 62, 98 andy reach for operator comfort and convenience. Forward and reverse drive “thumb” switches are located on both sides of the handle to accommodate left- or right-hand operation. An auto-reversing belly switch protects operators from potential injury when walking the unit backwards, while an automatic brake immediately halts travel when reversed. The Power Stacker is built on a short wheelbase to provide maneuverability in tight quarters. Two 12-volt, maintenance-free batteries provide power to the unit, and a 110-volt built-in charge is also a standard feature. Units are availablein fork-over design for use with open bottom pallets or adjustable straddle design for use with closed bottom pallets.
Presto Lifts, Inc.
www.prestolifts.com
Plant Engineering
Plant Engineering Staff
