Clamp column cover brackets
The clamp brackets enable quick installation column covers onto rectangular and round structural columns with large or small diameters.
The fabricated clamp brackets enable quick installation column covers onto rectangular and round structural columns with large or small diameters. Once fastened onto a structural column and attached to the first column cover section, the mating column cover section can be easily attached with brackets that accommodate both reveal and butt joint column covers. The clamps completely eliminate the need for on-site framing, fabrication, and complicated mounting clips typically required to secure exterior or interior column covers.
SAF Metal Fabrication
www.saf.com
