Arbitrary waveform generators
The arbitrary waveform generators allow easy signal generation in automation and remote applications.
The arbitrary waveform generators allow easy signal generation in automation and remote applications. The units combine digital-to-analog converter (DAC) technology and can generate signals from DC up to 400 MHz in frequency. Full remote control is achieved through a simple Ethernet connection to any PC or local area network (LAN) making them easy to integrate into any test system. The generators use DACs with 16 bit vertical resolution and offer output rates up to either 1.25 GS/s or 625 MS/s. They also include large on-board memories (up to 2 x 4 GB) and a generous output voltage range of up to ±4 V (± 5V for 625 MS/s models) into high impedance and ±2 V (± 2.5V for 625 MS/s models) into 50Ω.
Spectrum Instrumentation
www.spectrum-instrumentation.com
