The Liquiline CM44P can measure 16 different parameters from 6 analytical sensors simultaneously, simplifying monitoring of processes such as chromatography, fermentation, phase separation and filtration.
The Liquiline CM44P can measure 16 different parameters from 6 analytical sensors simultaneously, simplifying monitoring of processes such as chromatography, fermentation, phase separation and filtration. The CM44P accepts inputs from up to two process photometers and four analytical sensors simultaneously. Sensor types include pH, ORP, conductivity, dissolved oxygen, nitrate, turbidity, free chlorine and ion selective sensors. Mathematical functions allow the CM44P to calculate measured values on the basis of multiple input values. With the CM44P, plant personnel can obtain all of the quality and process information needed from a single transmitter, leading to reduced installation time, lower equipment costs, no need to acquire and manipulate data from multiple instruments, and simplified maintenance.
Endress+Hauser
