Air nozzle
The air nozzle delivers a small blowoff with an efficient, high volume, high velocity airflow.
The air nozzle delivers a small blowoff with an efficient, high volume, high velocity airflow. Its thermoplastic construction provides self-lubricating qualities with a low coefficient of friction to produce non-marring protection for sensitive materials. It can withstand harsh environments found in chemical, plating, etching and metal cleaning processes and thrives in seawater environments. Safe operation is assured since the airflow cannot be blocked, which meets the OSHA standard for dead-end pressure 29 CFR 1910.242(b). Sound level is at 68 dBA and meets OSHA noise requirement 29 CFR 1910.95(a), as well as being CE compliant.
EXAIR Corporation
www.exair.com
