Filtering hydraulic systems
Fluid power is one of the most reliable and repeatable forms of power and motion control. All that is required is a comprehensive state-of-the-art design and modern contamination control. When problems are encountered, 75% to 80% of the time they are related to inadequate contamination control practices.
07/08/2004
Key Concepts
  • Particle contamination causes most hydraulic system problems.
  • Cellulose or fiberglass media are used in most hydraulic filters.
  • Fluid condition can only be determined by analysis.
    Sections:
    Filter media
    Beta ratio
    Contaminant loading
    Standards changes
    Sidebars:
    Filtration facts
    For a hydraulic machine, the development of a target cleanliness level and a plan to achieve it are as important as the selection of pumps, valves, and actuators (Table 1). Many manufacturers specify the optimum cleanliness level required for their components. Proper selection and placement of filters in a system to attain the targeted cleanliness eliminates the root cause of most hydraulic system failures.
    System cleanliness assures the user of the hydraulic system a cost-effective approach to contamination control that allows the price of filters and elements to be quickly recovered by savings due to improved performance, increased component life, fewer oil changes, increased uptime, and fewer repairs (Fig. 1).
    Filter media
    Filter media usually start out in sheet form and are pleated to create more surface area exposed to the fluid flow, thus reducing pressure differential while increasing dirt holding capacity. In some cases, the media may have multiple layers and mesh backing.
    The most common media include wire mesh, cellulose, fiberglass composites, or other synthetic materials. Media are generally classified as surface or depth.
    The fluid stream basically has a straight path through surface-type media (Fig. 2). Contaminants are captured on the surface of the element. Elements are generally made from woven wire and the process can be accurately controlled for consistent pore size. The buildup of contaminant on the surface allows the media to capture particles smaller than the pore size.
    For depth-type media, fluid must take indirect paths through the material (Fig. 3). Particles are trapped in the maze of openings. Because of its construction, a depth-type filter has many pores of various sizes. Depending on the distribution of pore sizes, this medium can have a very high captive rate at very small particle sizes.
    The two basic depth media that are used for filter elements are cellulose and fiberglass. The pores in cellulose media tend to have a broad range of sizes due to the irregular size and shape of the fibers. Fiberglass media consist of fibers that are very uniform in size and shape. The fibers are generally thinner and have a uniform, circular cross-section.
    These fiber differences account for the performance advantage of fiberglass. Thinner fibers mean more pores in a given space. Thinner fibers can be arranged closer together to produce smaller pores for finer filtration. Dirt holding capacity and filtration efficiency are improved.
    Beta ratio
    The Beta ratio, also known as the filtration ratio, is a measure of the particle capture efficiency of a filter element. It is a performance rating.
    For example, assume that 50,000 particles, 10 micrometers and larger, are counted upstream of a test filter and 10,000 particles of the same size range are counted downstream of the filter. The corresponding Beta ratio would be 5.
    B x = no. of particles upstream /no. of particles downstream
    Where: x is a specific particle size
    B 10 = 50,000 /10,000 = 5
    The example is read 'Beta ten equal to five.' A Beta ratio number alone means very little. It is a preliminary step to finding a filter's particle capture efficiency. This efficiency, expressed as a percent, can be found by the equation:
    Efficiency x = (1 -1/ B ) 100
    Efficiency 10 = (1 -1/ 5 ) 100
    = 80%
    The particular filter tested was 80% efficient at removing 10-micrometer and larger particles. For every 5 particles at this size range introduced to the filter, 4 were trapped in the filter media. Table 2, 'Beta ratios and efficiencies,' shows some common Beta ratio numbers and their corresponding efficiencies.
    Contaminant loading
    Contaminant loading in a filter element is the process of blocking pores. As the element becomes blocked with particles, there are fewer pores for fluid flow, and the pressure required to maintain flow increases. Initially, the differential pressure across the element increases slowly, but a point is reached at which successive blocking of media pores significantly reduces flow through the element. At this point the differential pressure across the element rises exponentially (Fig. 4).
    The quantity, size, shape, and arrangement of the pores throughout the element accounts for why some elements last longer than others. For a given filter media thickness and filtration rating, there are fewer pores with cellulose media than with fiberglass media. The contaminant loading process blocks the pores of cellulose media elements quicker than identical fiberglass media elements.
    A multilayer fiberglass media element is relatively unaffected by contaminant loading for a longer time. The element selectively captures various-size particles as the fluid passes through the element. Very small pores are not blocked by large particles. These downstream small pores remain available for a large quantity of very small particles.
    Every filter element has a characteristic pressure differential versus contaminant loading relationship. This relationship can be defined as the filter element life profile. The actual life profile is affected by system operating conditions. Variations in the system flow rate and fluid viscosity affect the clean pressure differential across the filter element and have a well-defined effect on the actual element life profile.
    The filter element life profile is difficult to evaluate in actual operating systems. System operating time versus idle time, duty cycle, and changing ambient contaminant conditions affect the life profile of a filter element.
    Precise instrumentation for recording the change in the pressure differential across a filter element is seldom available. Most machinery users simply specify filter housings with differential pressure indicators to signal when the filter element should be changed.
    Standards changes
    Changes to ISO contamination and filtration standards were brought about to solve accuracy, traceability, and availability issues. It is important to remember that hydraulic systleanliness levels and actual system filter performance remain unchanged (Fig. 5). However, the reporting of cleanliness levels and filter performance has changed due to the latest particle counter calibration and multi-pass test procedures.
    It is important to note that the ISO 11171 calibration method is based on a distribution of particles measured by their equivalent area diameter. ISO 4402 is based on a distribution of particles measured by their longest chord. The NIST work utilized scanning electron microscopy for particles below 10
    The new calibration method and resulting ISO code typically produces a one to two-level increase in the first digit (the >4
    Plant Engineering extends its appreciation to the Eaton Corp., 800-547-7805, and Parker Hannifin Corp., 800-253-1258, for their assistance in the preparation of this article.
    Typical cleanliness codes (ACTFD size)
    Pressure 2000
    psi 3000
    Determine the cleanest level (lowest code) required by any component in the system.
    If the fluid is not petroleum oil, set the target numbers one lower.
    If at least two of the following are present, set the target numbers one lower:
    %%POINT%% Frequent cold starts at less than 0 F
    %%POINT%% Intermittent operation over 160 F
    %%POINT%% High vibration or shock
    %%POINT%% The system is critical to a process.
    Pumps
    Fixed gear
    20/18/15
    19/17/15
    Fixed piston
    19/17/15
    18/16/14
    Variable vane
    19/17/15
    18/16/14
    Variable piston
    18/16/14
    17/15/13
    Valves
    Directional
    20/18/15
    Pressure
    19/17/14
    Flow control
    19/17/14
    Check
    20/18/15
    Cartridge
    20/18/15
    Servo
    16/14/11
    Actuators
    Cylinder
    20/18/15
    20/18/15
    Vane motor
    20/18/15
    19/17/14
    Axial piston motor
    19/17/14
    18/16/13
    Gear motor
    21/19/17
    20/18/15
    Radial piston motor
    20/18/14
    19/17/15
    Beta ratio (at a given particle size)
    Capture efficiency, % (at the same particle size)
    1.01
    1.0
    1.1
    9.0
    1.5
    33.3
    2.0
    50.0
    5.0
    80.0
    10.0
    90.0
    20.0
    95.0
    75.0
    98.7
    100
    99.0
    200
    99.5
    1000
    99.9
    Filtration facts
    Properly sized, installed, and maintained hydraulic filtration plays a key role in preventive maintenance.
    The function of a filter is to clean oil; its purpose is to reduce operating costs.
    New fluid is not necessarily clean. Fluid right out of a drum is not fit for use in a hydraulic system.
    Additives in hydraulic fluid are generally less than 1 micron in size and are unaffected by standard filtration.
    Most system contamination enters through old-style breather caps and cylinder rod glands.
    Knowing the cleanliness level of a fluid is the basis for contamination control.
    The ISO code index numbers can never increase as particle size increases.
    Most hydraulic component manufacturers specify a target ISO cleanliness level.
    Color is not a good indicator of a fluid's cleanliness level.
    Surface media can be cleaned and reused. Depth media cannot be cleaned and is not reusable.
    Filter media ratings, expressed as a Beta ratio, indicate a media's particle removal efficiency.
    Always use an element condition indicator with any filter. A bypass prevents filter collapse.
    The only way to know the condition of a fluid is through fluid analysis. Visual examination is not an accurate method.
    All fluid analysis should always include a particle count and corresponding ISO code
